For this tutorial u need:
- Doosan robot
- Laptop with DRL studio - Homburger Hub, installed
- Cognex camera
For getting data from the cognex camera on a Doosan robot you need to set the Doosan IP address and the cognex IP address in the same IP range. If they are both in the same IP range then you can use the code below.
Configure these parameters
port = 10000
ip = "192.168.137.10"
then open a TCP connection to the camera
socket = client_socket_open(ip, port)
After connecting, the camera sends a welcome message and asks for a username and password.
receive = client_socket_read(socket, -1, -1)[1].decode()
client_socket_write(socket, "admin\r\n".encode()) # username + carage return, new line character
### Asked for a password ###
client_socket_write(socket, "\r\n".encode()) # password(empty) + carriage return, newline character
If successful, then you will get a logged-in message.
After the login procedure, trigger the camera. This function only works if the Cognex camera is on Online Mode
client_socket_write(socket, "SE8\r\n".encode())
wait(3)
triggerstatus = client_socket_read(socket, -1, -1)[1].decode()[:-2]
if triggerstatus != "1":
tp_log("Trigger failed: " + str(triggerstatus))
return 0
After triggering the camera, We can get the cell value from the Cognex table cell.
cel_data = "GVC019"
client_socket_write(socket, (cel_data + "\r\n").encode()) # GVC013
getvaluestatus, rec, _empty = str(client_socket_read(socket, -1, -1)[1].decode()).split("\r\n")
if getvaluestatus == "1":
# tp_log("GetValue successful: " + str(getvaluestatus))
rec = str(rec).split(",")
tp_log("GetValue failed: " + str(getvaluestatus))
After get the cell value, we need to close the connection
client_socket_close(socket)
The Full Code
def get_data_from_cognex(cel_data):
### Configuration of camera settings, adjust where needed ###
port = 10000
### Connect to camera and return status ###
### After connecting the camera first sends a welcome message and asks for username and password ###
# tp_log(str(receive))
client_socket_write(socket, "\r\n".encode()) # password(empty) + carage return, new line character
### user logged IN message ###
### Trigger camera, only works if camera is in ONLINE mode
# client_socket_write(socket, "SW8\r\n".encode()) #SW set event and wait gives an error and dont know why
client_socket_write(socket, "SE8\r\n".encode()) # SE set event does work but does not wait
wait(3)
return 0
wait(1) # Just to be sure, this can probably be removed
# tp_log("Received list:" + str(rec))
return rec
Input Name | Input Type | Description |
cel_data | string | GVxyyy this is the get value command. x is the letter of the cell where you want the data from. yyy is the number of the cell where you want the data from. For example GVC013 gets the value of cell C 13. |
This function returns an array of all the values in the defined cell that were sepperated using a ‘,’. We used it for getting the X and Y position, rotation and the number of the mold from the cognex camera. If the cognex camera gives no data then there was no good detection of the object.
X_Y_R = get_data_from_cognex('GVC019')
if (X_Y_R == ['']):
tp_popup('No mold detected please place mold in the detectable square', pm_type=DR_PM_MESSAGE, button_type=1)
return 0
_pos_x = float(X_Y_R[0])
_pos_y = float(X_Y_R[1])
_pos_r = float(X_Y_R[2])
_mold_number = int(X_Y_R[3])
This was the end of this tutorial, I hope it helped you. Good luck with your project!
Code Writen by A.Vonk
