First you must create your own computer vision code (in this case we using YOLO v8) and then you can create a socket server on your comvi program.
Socket Server (Laptop Side)
You need to create socket server that can run without interfere the comvi. Note that the data type have to be ‘string’. So here is the example.
from ultralytics import YOLO
import math
import threading
CONFIDENCE_THRESHOLD = 0.90
model = YOLO('Pizza&Crates_nano.pt')
cap = cv2.VideoCapture(1, cv2.CAP_DSHOW)
if not cap.isOpened():
print("Cannot open camera")
exit()
def get_rotated_rectangle_points(x_center, y_center, width, height, angle_degrees):
# Convert angle to radians
angle_radians = math.radians(angle_degrees)
# Half width and height
half_width = width / 2
half_height = height / 2
# Calculate the unrotated corner points relative to the center
corners = np.array([
[-half_width, -half_height], # Bottom-left
[ half_width, -half_height], # Bottom-right
[ half_width, half_height], # Top-right
[-half_width, half_height] # Top-left
# Rotation matrix for 2D rotation
rotation_matrix = np.array([
[math.cos(angle_radians), -math.sin(angle_radians)],
[math.sin(angle_radians), math.cos(angle_radians)]
# Rotate each corner point
rotated_corners = np.dot(corners, rotation_matrix)
# Translate the rotated points back to the rectangle's center
rotated_corners[:, 0] += x_center
rotated_corners[:, 1] += y_center
return rotated_corners.astype(int)
def draw_circle(circle, img, inside):
if inside:
colour = (0,255,0) # green
if not inside:
colour = (0,0,255) # red
cv2.circle(img,(circle[0],circle[1]), circle[2], colour, 2) # draw circel with colour
def draw_rotated_rectangle(image, rectangle_params, color=(255, 0, 0), thickness=2):
Draw a rotated rectangle on the image.
image: The image on which to draw.
rectangle_params: List [x_center, y_center, width, height, rotation (in degrees)].
color: Color of the rectangle (default is green).
thickness: Thickness of the rectangle edges (default is 2).
# Unpack the rectangle parameters
x_center, y_center, width, height, rotation = rectangle_params
# Get the four corner points of the rotated rectangle
points = get_rotated_rectangle_points(x_center, y_center, width, height, -rotation)
# Draw the rotated rectangle using polylines
points = points.reshape((-1, 1, 2)) # Reshape for polylines function
cv2.polylines(image, [points], isClosed=True, color=color, thickness=thickness)
def rotate_point(px, py, cx, cy, angle):
"""Rotate point (px, py) around (cx, cy) by 'angle' radians."""
# Translate point to origin
px -= cx
py -= cy
# Apply rotation
x_new = px * math.cos(angle) - py * math.sin(angle)
y_new = px * math.sin(angle) + py * math.cos(angle)
# Translate back
x_new += cx
y_new += cy
return x_new, y_new
def is_circle_in_rectangle(circle, rectangle):
Check if the circle is entirely within the rotated rectangle.
circle: List containing the circle's properties in the form:
[circle_x, circle_y, radius].
rectangle: List containing the rectangle's properties in the form:
[rect_x, rect_y, rect_width, rect_height, rect_angle].
# Unpack circle parameters from the array
circle_x, circle_y, radius = circle
# Unpack rectangle parameters from the array
rect_x, rect_y, rect_width, rect_height, rect_angle_deg = rectangle
# Convert the rectangle's rotation from degrees to radians
rect_angle = math.radians(rect_angle_deg)
# Step 1: Rotate the circle's center point to align with the rectangle's axis
rotated_circle_x, rotated_circle_y = rotate_point(circle_x, circle_y, rect_x, rect_y, -rect_angle)
# Step 2: Get the rectangle's boundaries
half_width = rect_width / 2
half_height = rect_height / 2
# Step 3: Check if the circle lies within the rectangle's boundaries (accounting for the radius)
if (rotated_circle_x - radius >= rect_x - half_width and
rotated_circle_x + radius <= rect_x + half_width and
rotated_circle_y - radius >= rect_y - half_height and
rotated_circle_y + radius <= rect_y + half_height):
return True
return False
def Boundingbox(results, yolo_image):
for result in results:
obb = result.obb.cpu().numpy()
results_xywhrs = obb.xywhr
results_class = obb.cls
circles = []
rectangles = []
for results_xywhr, cls in zip(results_xywhrs, results_class):
if cls == 1:
X_middle = int(results_xywhr[0])
Y_middle = int(results_xywhr[1])
radius= int((results_xywhr[2] + results_xywhr[3]) / 4)
circles.append([X_middle, Y_middle, radius])
if cls == 0:
rotation = results_xywhr[4]
rotation = int(rotation * 180 / math.pi)
rectangles.append([X_middle, Y_middle,results_xywhr[2], results_xywhr[3], rotation])
return(circles, rectangles)
def amount_in_crate():
success, yolo_image = cap.read()
#apply moddel on image
results = model.track(yolo_image, conf=CONFIDENCE_THRESHOLD)
# Get position of the boundingboxes
circles, rectangles = Boundingbox(results, yolo_image)
# check & count pizza's in crate
pizzas_in_crate = 0
for rectangle in rectangles:
draw_rotated_rectangle(yolo_image, rectangle)
for cicle in circles:
is_inside = is_circle_in_rectangle(cicle, rectangle)
if is_inside:
pizzas_in_crate += 1
draw_circle(cicle, yolo_image, is_inside)
if (len(rectangles) == 0):
draw_circle(cicle, yolo_image, False)
cv2.imshow('frame', yolo_image)# show image
return(pizzas_in_crate)
class TCPServer:
def __init__(self, host, port):
self.host = host
self.port = port
self.server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
self.server_socket.bind((self.host, self.port))
self.server_socket.listen(1) # Listen for up to 1 connection
self.conn = None
self.address = None
def handle_client(self):
if self.conn is None:
self.conn, self.address = self.server_socket.accept()
print(f"Connection from: {self.address}")
print("Calling amount_in_crate()")
pizzas = amount_in_crate() # Get the number of pizzas
print(f"Pizzas in crate: {pizzas}")
self.conn.send(str(pizzas).encode()) # Send the number to the client
data = self.conn.recv(1024).decode() # Receive data from the client
if not data:
print(f"Message from client: {data}")
except ConnectionResetError:
print(f"Connection reset by client: {self.address}")
self.conn.close()
self.conn = None
self.address = None
print(f"Error occurred: {e}")
self.conn.close()
self.conn = None
self.address = None
def start(self):
client_thread = threading.Thread(target=self.handle_client)
client_thread.daemon = True
client_thread.start()
# Start the TCP server in a separate thread
tcp_server = TCPServer('192.168.123.201', 20002)
tcp_server.start()
while (1):
start_time = time.time() #start timer
print(amount_in_crate())
print("My program took", time.time() - start_time, "to run") # print cycle time
# end when q is pressed
if cv2.waitKey(1) == ord('q'):
cv2.destroyAllWindows()
As you can see we created TCPServer class to create function for TCP server, create new thread, and client handling so the main computer vision program still can continue processing the image.
Socket Client (DRL Studio)
You must run the client code on DRL and you can run it on just one laptop (You can do 2 laptop but that is unnecessary). NOTE that DRL Studio has limitied core library because it only support python 3.2.
from DRCF import *
sock = client_socket_open("192.168.123.201", 20002)
while sock:
msg = "Robot is ready!"
client_socket_write(sock, msg.encode()) # request data from camera
res, rx_data = client_socket_read(sock) # receive data from camera
rx_msg = rx_data.decode() # decode data from server
tp_log("{0}".format(rx_msg))
If the connection estabilished, the robot will send the message “Robot is ready!” to the server.
